Okay, where to start... I am planning on installing a all-in-one radiator for my new gaming desktop I'm building but I'm wondering what I should use to cool it. I've looked up Noctua fans and Corsair fans, but I've only looked at Corsair all-in-one radiators. I just need help choosing between a H100i (or H105) but upgrading the fans to the Corsair SP120 performance editions because they have a very high static pressure, higher than any Noctua fans.
My next problem is wither I should get the H110? I know it is a much larger radiator and using 140mm fans, but I can't seam to find any good 140mm static pressure fans that don't have LEDs on them. But would having a larger radiator with less powerful fans be better? I honestly don't know...
If there is such a thing, I would really like a 360mm wide radiator or even a 420mm all-in-one radiator because I want to overclock my new i7 5960x sky-high to around 4.5GHz-5GHz without it getting too hot (75'c+). I'll be installing it into my old case (InWin GRone) and because it supports a 140mmX3 radiator at the top, I really want to use that. I would set it up as a push/pull with it pushing the air out of the case and it'll also be used like a exhaust, along with the 140mm fan at the back.
Before you ask "Why don't you install a custom loop?" The answer to this is because I don't want to install a custom loop and blow my entire system. Hence I want an all-in-one because they're easy to install and there isn't a chance of a leak, destroying the system.
Hope you guys can help because I really want the best cooler with the largest radiator with strongest fans. Price within reason, is not a problem.
Hope you can help.
- Joe
Hope you can help.
- Joe
