P panoz Honorable Jan 23, 2013 23 0 10,510 Aug 24, 2015 #1 Hello there i just want to buy a new graphics card and i was thinking about Asus GTX 970 Strix.However im wondering if this graphics card fits in my mid case,which is Aerocool Strike-X One.
Solution Clamyboy74 Aug 24, 2015 It fits because your case can support up to 400 mm long GPUS. The GTX 970 is only 279.4 inches long. Links case- http://www.aerocool.us/strikex/strikex_one.html GPU- http://www.newegg.com/Product/Product.aspx?Item=N82E16814121899
Clamyboy74 Reputable Oct 25, 2014 148 0 4,710 Aug 24, 2015 Solution #2 It fits because your case can support up to 400 mm long GPUS. The GTX 970 is only 279.4 inches long. Links case- http://www.aerocool.us/strikex/strikex_one.html GPU- http://www.newegg.com/Product/Product.aspx?Item=N82E16814121899 Upvote 0 Downvote Solution
P panoz Honorable Jan 23, 2013 23 0 10,510 Aug 25, 2015 #3 Thank you very much mate i really appreciated your help. Upvote 0 Downvote
