I Need Your Help !!!
SamikSamik
119
I am planning to get 5850 ..I am not overclocking ...not using more than 1440 resulation & dont want to Crossfire ...now please tell me
1.will it work fine on my current GA P31 DS3L Motherboard ?
2.which is recomended power supply for this card ?
My system is:
Core 2 Duo 1.8Ghz E2160 installed on GA P31 DS3L S3 Mobo with 4GB 800Mhz ddr2 ram & 430 powersupply ....Brand is GreenPower Model:ATX12V Ver2.0 Dual Line +12V ... Which Hardwares should be UPGARDED to 5850 work fine on my PC ?
jonpaul37
2,481
that motherboard will have no problem with the 5850 but you may need a new power supply, you want at least a good quality 500-watt power supply with a high amp value on the 12v rail. Good power supply brands are seasonic, Corsair, Antec. Also, that CPU will be able to handle the 5850 but it will not push it to its fullest potential. You will need to either overclock that CPU or get a beter one like an E8400 (that is if the E8400 will work in that motherboard) I would suggest getting a CPU support list for that motherboard.
SamikSamik
119
My Motherboard Supports Multi Processors ... Even Quad Core ...but i am not sure it will fully support's Q9400 OR NOT ... E8400 is good but ....Q9400 is Great !! So how do i get a CPU support list ? should i get it from a site ?? Thanks for your advice it realy helped me to solve my decision !
SamikSamik
119
As i saw Q9400 in the list ..it means that my mobo fully support it ....or not ? if yes so will it run great on my Mobo or will have a lot of problems ? i saw in youtube that some one was playin GTA IV with GA P31 DS3L [My Mobo Kind ] wiht Q9550 .. so it seem that mobo realy can support it !! what do you think ?? ;)
jonpaul37
2,481
from what i can see, it will support basically any core 2 duo or core 2 quad, may require a BIOS upgrade though. I would update to the latest BIOS and then you should be good for the CPU of your choice.
You will definitely need a better power supply of at least 500-watts or better. My suggestion would be at least a Corsair TX650, it is a great power supply and will last you quite some time, even if you choose to crossfire another 5850.
SamikSamik
119
Thanks A lot my Friend .. & the Last thing that i want to say is ...How to update my bios ..& how it will help me to run Quad core fine ....? are you realy saying that i can run it fine on my mobo ?!! thats great ..Any way thanks a lot for helping me :D :hello: OH ... what do you think about GREEN - GP785B & GREEN - GP885B are they better than what youve suggested me !? :p
jonpaul37
2,481
there should be a download for the BIOS updater on the Gigabyte website.
As for the Green-series Power supplies i am not sure. Other good brands are as follows:
Corsair
Seasonic
PC Power & Cooling
Antec
Enermax
SamikSamik
119
You Gave me the Best Answers Till now .. Thanks a lot my friend :hello: :D i will go for Crosair as you say !
SamikSamik
119
I like ASUS but somany say it burns & breaks so soon after useing .. i am in IRAN ... & i am not sure that MSI or Asus That u use there is Same i use here ... i am not IRANIAN ... but i am livin here ... WHAT do you think about GIGABYTE ? it hs highest price in here & AS same as ASUS cards .... please tell me its good or bad & why it is .. ??
SamikSamik
119
Why someones telling me you mayhave a SPACE problem with GA p31 DS3L Mobo if you get 5850 ! ... my mobo is 8.5 long as the say ...& 5850 is 9.5 long ...so how can it work fine on my MOBO ? PLEASE EXPLAIN me
SamikSamik
119
I have { Porsche } now ...& it seem to be a Big case ... if it handles my 9600 so little longer VGA wouldnt be big problem ... some said that the problem is power CABLE ... what do you need to know to help me more about this ?
SamikSamik
119
My Case is 17.32 Inches {44 CM } Long 7.87 {20CM} Wide from front & rear & 18.89inches {48CM }Wide from Sides ...Sides removable Covers I mean ...SO NOW WHAT ...WILL it help you to know if 5850 fits or not ???
SamikSamik
119
You Told me that GA P31 DS3L wiht 4 GB RAM DDr2 800 MHZ is fine for 5850 & i believe it ... but why shopkeepers still saying your mother board cant provide all 5850 needs .. please explain me ..its not about matching with my MOBO its about run fast & great ..
jonpaul37
2,481
you can take their word for it if you like but i have been enthusiastically building PC's for years and i know for a fact that your motherboard with a Q9550 and 4GB of DDR2 800 RAM will handle a 5850 just fine.
If there is Anyone else that reads this, please chime in...
SamikSamik
119
OK now i am sure about what youve said for 100% THANKS A LOT .. They Care About theire Money i think ...thats why they want me to buy much more than a 5850 .. THANKs A LOT MY Friend
