Question I neep help with chosing!
Feb 7, 2020
34
4
35
Hi guys, I need help with choosing my storages since I don't know which are good or bad etc. Beneath are the specs of the build that I've kind of put together with help from others. I'm buying the build today as soon as possible.
CPU: AMD Ryzen 5 3600 (1990 sek/205 usd)
GPU: Sapphire PULSE Radeon RX 5600 XT (3590 sek/370 usd)
Case: Fractal Design Meshify C (1149 sek/118 usd)
Motherboard: ASUS ROG Strix B450-E Gaming (1790 sek/184 usd)
Ram: Corsair Vengeance LPX Black 16GB (2x8GB) 3200 mhz cl 16(999 sek/103 usd)
SSD: ?
HDD: Toshiba Intern Hårddisk P300 2TB (7200rpm) (679 sek/70 usd)
PSU: Corsair RM650 650W (2019) (1090 sek/112 usd)
Fans: Inet Tyst 140mm Fläkt, v2, Svart (99 sek/10 usd)
Monitor: Acer 24" Predator XF240H 144Hz (2190 sek/225 usd)
My options for SSD:
Crucial BX500 240GB SATA 2.5" 7mm (CT240BX500SSD1)
Kingston SSDNow A400 M.2 SSD - 240GB
WD Green 3D NAND 240GB SSD (WDS240G2G0A)
Kingston A400 240GB 2.5" SATA (SA400S37/240G)
PNY CS900 2.5" SSD 240 GB
Intenso SSD SATA III High Performance
Toshiba OCZ TR200 240GB
My options for HDD:
Seagate Intern hårddisk Barracuda Compute HDD 2TB (7200rpm)
Would highly appreciate every answer, if there are some other changes that you would like to make in this build please let me know.
Thank you!
Wolfshadw
If you're going to go with the 3rd Gen Ryzen CPU and a B450 motherboard, go with one of the MSI "MAX" series motherboard or a motherboard with the Flashback BIOS feature so you can update the BIOS without needing another CPU, if needed.
As for the SSD, I'd probably opt for the Kingston M.2 240GB drive.
-Wolf sends
Feb 7, 2020
34
4
35
-Wolf sends
Thank you for the reply, I was thinking about going with Crucial BX500 240GB SATA 2.5" 7mm (CT240BX500SSD1), and with the Toshiba Intern Hårddisk P300 2TB (7200rpm) what are your thoughts about that. Appreciate the time :)
Feb 20, 2020
59
6
45
-Wolf sends
I have the b450 A Pro Max and from what ive heard their VRMs are decent at overclocking with as they have pretty decent heat sink over them, someone got 4ghz on a 2600 at 1.325v, although i have not attempted overclocking yet. So it could be a decent option for him/her i got mine for £80 in the uk.
Feb 7, 2020
34
4
35
Take your pick really. The only reason I suggested the Kingston was to make use of one of your M.2 slots.
-Wolf sends
Thanks for the reply, the retailer told me to get the WD Green 3D NAND 240GB SSD (WDS240G2G0A) and the Seagate Intern hårddisk Barracuda Compute HDD 2TB (7200rpm). What do you think about that? And I went with the Asus rog strix b450-e gaming with and updated bios ready for 3rd gen :)
Feb 7, 2020
34
4
35
Thanks for the reply, unfortunately, I needed wifi and bluetooth so that's why I went with the Asus rog Strix b450-e gaming:)
Feb 7, 2020
34
4
35
I'd say the retailer probably has plenty of those in stock and that's why they recommend them. Other than that, I don't have a problem with that selection (or any other).
-Wolf sends
Might be true, the retailer said that the wd is the most reliable brand and that the seagate is the most used hdd and that they even use that exact hdd for their own pcs.
