I put duct tape inside of my Desktop to hold up my fan that I just bought. Will it hurt my PC at all?
capsto
Commendable
Apr 28, 2016
43
It came without screws so it was a quick fix. I just hope it does not hurt anything inside of my PC. I hope that it won't. So far it is running just fine and in fact it is actually running smoother.
no. apart from the adhesive on the tape drying and hardening and being hard to clean.
fans weigh nothing. I have used rope caulk, that poster adhesive paste. hell bubblegum in a pinch.
No, your computer is completely fine and there is no problem with it! I suggest you find some screws that you can get since you will not want to hold the fan up with duct tape for ever! But no don't worry your computer is completely fine!
