I wanted to know how to check if everything is working properly,led lights and fans are spinning but I want to know if there's a specific software that will tell me if the radiator is working like its supposed to be?
Not knowing what your CPU is, but if your CPU temps are good, everything is working. Generally you want to set the pump (header) to run at 100% speed/duty cycle, which will ensure maximum water flow.
