Here is what happened: I was troubleshooting why a newly bought M.2 SSD was making my other SATA SSD boot drive no longer work, while it was connected and was trying to move those oh so stubborn SATA cables to different ports on the motherboard. Not able to get to them,I was attempting to remove my GPU from its PCI slot and as my hands could not fit between it and my NH-D15 heatsink, I was using a flat head screwdriver to push the lever to release the GPU. Like a complete idiot,I forgot to turn the PSU power off again (I had been turning it off and on a lot in my troubleshooting and removing/reconnecting things) and the screwdriver slipped and hit the metal contacts of the nearby M.2 drive meant for Optane sized sticks. I saw a small spark and the system turned itself on and I think I might have done this without realizing a previous time as well as at one point before, the system turned itself on again. Like I said, I had been turning the switch off and on again and was too busy thinking of what to do next to remember to turn it off. There were several times I tried to power on only to realize the PSU switch was off, as well. Now, when I turn it on, the power light does not light up, my GPU fan (Vega 64 blower card) does not spin (tried two different PCI-e slots) and one of the system intake fans do not spin. I switched its cable to another slot and put on my of CPU heat fans on the same port it was on and confirmed its the port not putting power out as nothing connected to it spins. Finally, it fails to POST and the MSI Debug lights only show the CPU light on solid white with no other lights coming on and no HDD activity at all, no matter what. I have tried using onboard HDMI and taking off the discrete GPU and have gone through the effort of reseating the CPU, new thermal paste and all, to no avail. Does anyone think there is a way to salvage it without buying a new Mobo? I just spent $300 on that 970 Evo and another 16GB of memory. Kinda strapped for cash now. Relying on an old as crap laptop right now. BTW, I know the memory is good because I had previously booted into Windows with the full 32GB working fine.
CPU: i7 8700K
Mobo: MSI Z370 SLI Plus
CPU: i7 8700K
