my Cooler is a Hydro Series™ H100i v2 Extreme Performance Liquid CPU Cooler
I got tired of my PC freezing over and over to the point I take my PC in (they fix it, lasts a day or 2) than I read online that the FX-9590 is overclocked from the factory (speedfan showed hot temps) if you don't mess around in your PC Bios and disable Turbo.......so I went into my Bios and clicked Advanced than I found
AMD Turbo CORE Technology>AUTO I set to disable
CPU Spread Spectrum>AUTO I set to disable
PCIe Spread Spectrum>AUTO I set to disable
since I did that, speedfan shows much cooler temps and PC never froze since
and I'm running 2 browsers right now with a total of 17 tabs and most are youtube videos and even after hours of gameplay PC is fine
