Hi my new build is not complete yet, I have the PSU, the RAM, the mobo, and the case. (all brand new)
This is it so far:
ASRock Z77 Extreme4
Corsair TX650 80+ Bronze
Corsair Vengeance 8GB (2x4GB)
RaidMax Quantum
I have fitted the mobo, RAM and PSU. But since this is my first build I am not really too sure how to fit the PSU to the mobo and make it work.
I have tried fitting it all together but nothing happened.
I thought this was down to my PSU so I ran a test on it to see it if worked and it worked fine, so I'm thinking that it is my mobo because none of the LEDs are coming on, none of the fans are spinning and there is no power in anything whatsoever.
Also because I haven't really got that much of an idea where all the cables plug into I have only plugged in the 24-pin connector, but the mobo just won't do anything.
I would really like a tutorial of how to plug it all in, and how to find out if it is indeed my mobo because then I can think of sending it back.
All of my parts are brand new and were sealed until I opened them, so it may be a faulty mobo, but I was just gonna post this first to find out if there is anything I can do to test it and if I have all the wires correctly plugged in.
Thanks
Gillfreex
This is it so far:
ASRock Z77 Extreme4
RaidMax Quantum
Thanks
Gillfreex
