Question I think my graphics card is faulty
Jun 28, 2022
4
I just purchased a gigabyte vision oc 3060 12gb Gpu and it doesn’t seem to work, I know it’s compatible with all my other parts but I just can’t figure out why it won’t work. I tried my old gpu and it works perfectly but with this one when I turn on the pc, it just gives me like rainbow static across the screen. Has anyone had this issue or knows what could be wrong
Jun 28, 2022
4
What is the full pc spec?
The comment about ‘rainbow static’ immediately makes me think a faulty card.
Cpu : intel i7 10700k
Motherboard : mag b560 torpedo
Gpu : gigabyte rtx 3060 vision of 12g
Power supply : evga b5 650
Ram : Corsair vengeance 16gb
everything seems to work, I can get to windows running through the motherboard and also it works with a different gpu but this one just goes to static
Nothing stands out as a possible cause apart from a faulty gpu. Can you try the gpu on another pc and see if does the same?
Jun 28, 2022
4
I just tried it in my old pc and it seems to boot up to windows perfectly? I really don’t understand, do you think it just doesn’t have enough power maybe?
Jun 28, 2022
4
Never mind it is not working, it’s using Microsoft basic display adapter instead of the new gpu
