I think my pc is infected.NEED HELP!
gyneshwar
75
Hey everyone,
I recently noticed that my internet is being consumed even without me doing anything.Hence i installed avast and found about 30 infected files and removed them.I also installed adwcleaner and removed 4 more.But my bandwidth meter still shows data being consumed.What do I do?
You need to follow these options for fix your computer problems then it will start working fine.
1. run cleaner on your computer.
2. now you need to run malware bytes antimalware on your computer.
3. once you will run these both softwares on your computer. then you need to run hitman pro on your computer. then it will clean your computer properly.
and if your computer will be infected with the viruses. then it will remove the virus from your computer and make your computer secure.
don't forget that windows 10 cross loads onto people's pcs and then are shared out over internet in a p2p network sharing to crossload onto other pcs and give microsoft a lot of free bandwidth (both for windows 10 itself and windows 10 updates, you don't even need to have windows 10, just the installer will "volunteer" your network to microsoft). if he has the windows 10 installer on his pc it might be that as well.
also utorrent loads mining viruses, and gog galaxy does a lot of p2p sharing as well.
