I wanna build a low gaming pc and i have some questions.
Andrei Draghia
39
Hello community!
I wanna buy a processor+motherboar+4 gb ddr3 ram
And i have this in my mind for some nice prices
http://www.msi.com/product/mb/H97M-E35.html#hero-overview and intel g3220 Haswell http://ark.intel.com/products/77773/Intel-Pentium-Processor-G3220-3M-Cache-3_00-GHz
+ 4 gb DDR 3 ram
or asrock 870 extreme3 http://www.asrock.com/mb/AMD/870%20Extreme3/index.asp?cat=
amd phenom II x2 555 black edition 6mb http://www.newegg.com/Product/Product.aspx?Item=N82E16819103846
+cooler katana 2+ 4gb DDR3
I own a HD 7750 1gb ddr5 and Noname source 550w but i dont know how many are real.
What do you guys think?
BTW... i3 2100 is old, get the i3 4130 which is newer and supports your motherboard.
I3 will be better in games like battlefield 4, but for older MMO's like War Thunder and Minecraft, the g3220 would be fine.
CPU doesn't render Games, GPU does. I3 wount cut it and will bottleneck.
4 cpu cores are still the best for gaming so go with AMD fx-6300 (6 cores)
please use PCpartpicker.com to build your PC
Also go with 8gb (2x4gb) of ram. If youre going to go with 4gb(2x2gb) then install Windows 32 bit.
Here's an example of something cheap that will run your games in Full HD
PCPartPicker part list: http://pcpartpicker.com/p/4gD4mG
Price breakdown by merchant: http://pcpartpicker.com/p/4gD4mG/by_merchant/
CPU: AMD FX-6300 3.5GHz 6-Core Processor ($94.89 @ OutletPC)
CPU Cooler: Antec KUHLER H2O 650 Liquid CPU Cooler ($37.49 @ Newegg)
Motherboard: MSI 760GM-P34 (FX) BOM Micro ATX AM3+ Motherboard ($53.98 @ Newegg)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory ($59.99 @ Newegg)
Storage: Hitachi Ultrastar 1TB 3.5" 7200RPM Internal Hard Drive ($40.00 @ Amazon)
Video Card: Asus GeForce GTX 660 2GB Video Card ($119.99 @ Newegg)
Case: Enermax ECA3253-BL ATX Mid Tower Case ($37.99 @ Directron)
Power Supply: CoolMax 600W 80+ Bronze Certified Semi-Modular ATX Power Supply ($29.99 @ Micro Center)
Total: $474.32
Generated by PCPartPicker 2015-02-25 10:24 EST-0500
Yeah there is a noticeable difference in gaming because i3 2100 has four logical cores and the dual core only has two .
I3 2100 is better but its socket is obsolete .
But with G3220 you could upgrade to i5 Haswell later .
So if you want to upgrade later pentium is the best for you.
And if you go for pentium buy the G3258 not the G3220 because if you overclock it [even on stock] it will run most new games except farcry 4 and AC unity and other badly optimized games.
Hope this helps.
I dont have money for what you guy said above me,so the dual core g3258 is ok because i can upgrade later with a better processor no?This processor will run good with my hd7750 and my powerlink 550watts source?I will have problems?
Now i have a dual core e5200 2.50 ghz and 4gb ram ddr2 and the pc is kinda fine no problems atm.
As far as i know the HD 7750 requires only 75W . It can even run on a 350W PSU. So you`re safe there.
And G3258 is great choice for you . It can overclock to 4 Ghz on stock cooling.
Yep you`d be able to upgrade to core i3/i5/i7 Haswell later.
Beefy games like AC unity Far Cry 4 and MMOs wont run but still you`ll be able to play most single player games .
Hope this helps
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116950&cm_re=g3220-_-19-116-950-_-Product this is the processor i will get since i cant get the G3258. and this is the mboard http://www.msi.com/product/mb/H97M-E35.html#hero-overview
For the G3220 i need ddr3 1333 mhz no?By the way i dont wanna play the new games i just play CS.Go,Dota 2 and Aion online will those game run better and there will be a difference from what i got now?
Now i own as i said a dual core e5200 2.50 ghz and a cheap mboard from asus and 4 gb ddr2.
I'd personally buy an 860K (or something similar like an i3) and stick with it. Especially with DX12 around the corner where strong CPUs will become pretty much irrelevant for gaming. Get anything that can handle a minimum of 4 threads, and you'll be fine for a long while. Forget the G3258.
Woah Man! Are you sure that Strong CPUs will become irrelevant?
