i wanna help please
Youseef Mohamed
4
i have bought a new PC and it is the system core i3 3.30 ram 4GB AMD radeon 5450 2GB the problem is i want to make the best use of my PC in playing modern games because most of the modern game work slowly even NFS most wanted in the best graphic setting please reply
From one review, the hd 5450 = intel hd3000, that is in the bottom. You may need at least the HD 7770 or up, that depends on your budget, check out the "Best Graphics Cards For The Money: January 2015" http://www.tomshardware.com/reviews/gaming-graphics-card-review,3107-7.html Also you may need the new PSU too.
Here is the review http://www.notebookcheck.net/Need-for-Speed-Most-Wanted-Benchmarked.83880.0.html
I almost forget do you have the i3 2120 3.3ghz...
I almost forget do you have the i3 2120 3.3ghz? http://ark.intel.com/products/53426/Intel-Core-i3-2120-Processor-3M-Cache-3_30-GHz if yes, the cpu is fine. You need new GPU and PSU, depends on what PSU you had.
