I want help with choosing a headset
dasp0
30
I am mainly going to play Counter-Strike: Global Offensive at a competetive level.
I am semi pro and want some help with a headset.
I have used hyperx cloud 2 but they fucked up after just 3 months so I am not going to buy a new pair. What do you guys have to recommend to me?
I have the built in sound card from Asus z97-a and I have no idea if that is enough or even qualified as a soundcard.
I don't know which headsets I can buy and which that supports my built in soundcard or whatever so it's kinda hard. Also every headset seems to be bad from what I have read. Except sennheisers.
Anyway. I would like to get a headset that doesn't require a soundcard because I can't afford soundcard and a headset atm and I am really in need of a headset.
Oh btw my budget is about 220 dollars
Nope, no sourround on the PC 350 mate.
Go for the PC 363D (Wired), and in the future (for extra sound quality), buy a USB DAC or the Sound Blaster Z Sound Card.
Or, if you want to go wireless, Logitech 933 seems like a great option.
