I want to build a gaming PC Help me choosing components
ritssvyas778
45
I want to build a g PC that can play games at 1440p@60(ultra settings if possible), Streaming games and Video editing
My budget is 150000 Indian Rupees including monitor(1440p possible if fits in budget or 1080p will be fine), Keyboard(Mechanical), mice, Headphones(Gaming)
Suggest me from this sites Md computer itdepot primeagbg or any good indian site
I dont care about RGB lights
And I know how overclock the cpu and gpu
So please suggest me Components
Please dont use PC partpicker coz it has wrong price.
Since I can't use PCPartPicker, I'm gonna recap what you need, and you can figure out the rest for yourself.
Ryzen, because you want to stream and do video editing too. Ryzen is better suited for this than Intel.
Start with a Ryzen 2600(X) and build from there. Use either an X470 or a B450 motherboard, not a B350.
You'll need 16GB of DDR4 RAM, preferably 3200 MHz CL14 or better.
For 1440p you'll ideally need a GTX 1070 or a Vega 56. If you can live with medium settings, an RX 580 or GTX 1060 6GB can suffice.
Add an HDD and SSD within your budget and your PC is done.
As for keyboard, you'll have to determine if you want mechanical or not, and if you do, which switch.
For mouse, something like the Logitech G402 is good for almost anybody.
For headphones I recommend the Kingston HyperX Cloud.
Good luck.
PLease Give me specific componenmt models, coz I dont want to screw up my money
