hey all, this is my first post. I am planning a build using Dan-Case C4-SFX and I am trying to figure out which GPU’s wil fit with no modification to the GPU.
I first saw this case in a Linus Tech Tips video where they modify a Gigabyte Aorus RX 7900 XTX to fit it. Then I saw a video by Optimum showing an MSI RTX 4080 Gaming X Trio fitting with no modifications. The Gigabyte is 335mm long and doesn’t fit in Linus’s video, Dan-Case states 336mm as the max length, and the MSI is 337mm and fits no problem.
I want to put a Gigabyte RTX 4070Ti which measures (336x140x58)
GPU dimensions
Gigabyte Aorus RX 7900 XTX (335x137x69)
MSI RTX 4080 Gaming X Trio (337x140x67)
Gigabyte Gaming OC RTX 4070Ti (336x140x58)
LinusTechTips GPU does not fit w/o modification:
View: https://youtu.be/f4k6xRfmz2A
Optimus showing it fitting just fine:
View: https://youtu.be/PpENpqI7BiE
Any help or insight would be greatly appreciated.
best regards,
K
GPU dimensions
best regards,
K
