[SOLVED] I want to build my own system but...
phidarian
16
I want to build my own system, but I haven't built a system in about 10 years. I'm hoping to get a 3070 or 3080. I have a monitor and a mouse, and I can get Office and Windows for free through my university which should save a lot of money.
Alternatively, I was looking at buying a rig from Alienware, but (and again it's been 10 years or so) the last time I compared buying vs building my own I saved like $600 for about an hour of labor. Is that still the case? Anyway, I'd appreciate suggestions for a gaming rig. I'm hoping to keep it under $2k but I'm flexible. I want this system to LAST so if I have to pay silly prices I'm a little bit okay with it. Not 3090 silly, but 3080 might be doable.
Thanks! (The following edit was for clarity, as suggested by @USAFRet (thx!).
Approximate Purchase Date: e.g.: this week (the closer the better)
Budget Range: $2,000
System Usage from Most to Least Important: Zoom/gaming
Are you buying a monitor: No (I will eventually, but it doesn't need to happen right now)
Parts to Upgrade: My laptop is literally dying. Keys are falling off, the battery no longer charges, and it's pushing 10 years old. I intended for it to last five.
Do you need to buy OS: No
Preferred Website(s) for Parts: Cheapest reliable site. Whatever you guys think is best.
Parts Preferences: I'm looking for bang for buck here, but broadly speaking I prefer Intel and nVidia. If there were compelling reasons to go elsewhere, I would.
Overclocking: I won't have the funds to replace a CPU I screw up in the near future, but once I do I'll probably give overclocking a shot.
SLI or Crossfire: No monies atm (I would really like to stick to IVO $2,000), but if there's no price difference I prefer an SLI capable setup for future upgrades.
Your Monitor Resolution: My monitor is a 1080p dinosaur. I will upgrade it down the road, but atm I mainly play League of Legends and I need it for working online, so it's not a priority. (For those wondering why I'm upgrading at all if that's the case, see below.)
Additional Comments: Webcam recommendations are welcomed - my work requires conference calls. The price doesn't need to be included in the rig though.
And Most Importantly, Why Are You Upgrading: My Alienware 18 is like 10 years old. Keys are literally falling off and the battery won't charge past 1%. Dell wants about $400 to replace the faulty parts with refurbished parts. I can't express enough how happy I've been with this laptop overall, but it's time to put her out to pasture. Yes, I did consider buying another Alienware laptop and you kind gents can't come up with a reasonable build it's definitely what I'll do, but I feel like a tower will last longer and be easier to service and find parts for.
I went a bit overboard, on the storage, but with games getting so big, a large SSD isn't a bad thing. I would use the HDD, for documents, video, pics, and such. Keep in mind that 4th gen ryzen 5000 will be out in november.
PCPartPicker Part List
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor ($294.99 @ Amazon)
CPU Cooler: ARCTIC Liquid Freezer II 240 56.3 CFM Liquid CPU Cooler ($99.99 @ Amazon)
Motherboard: Gigabyte B550 AORUS ELITE ATX AM4 Motherboard ($149.99 @ Amazon)
Memory: Crucial Ballistix 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory ($149.99 @ B&H)
Storage: Silicon Power A60 512 GB M.2-2280 NVME Solid State Drive ($54.99 @ Amazon)...
Thanks!
If you are hoping to keep your budget under $2K there's zero reason to consider going pre-built. If you want a pre-built system it's either for people with very little money to burn (like Cyberpower, MSI, Omen, etc) or people with deep pockets (Falcon Northwest, Maingear, Origin), there really is no in between. For $2,000 you can get a much better system if you build it yourself vs what you can get if you go the pre-built route.
The issue is that I've been out of the game for about a decade. If I'm building it myself, I need someone to tell me what to buy and build. I have no idea what parts are compatible/ideal/etc anymore.
As has been stated on your budget if you want a 3070 or 3080 you're most likely going with a Ryzen 3700X to keep things under $2,000. I am not big on the current generation of Intel mainly because of power consumption requirements, but that is mainly a preference thing. You can't go wrong with the current generation of AMD - it's more cost effective than Intel and matches or beats it on most tests.
Sorry I wasn't that clear; if I go prebuilt, it will be a laptop.
Storage: Silicon Power A80 2 TB M.2-2280 NVME Solid State Drive ($229.99 @ Amazon)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive ($54.99 @ Newegg)
Video Card: EVGA GeForce RTX 3080 10 GB XC3 GAMING Video Card ($749.99)
Case: Metallic Gear Neo Air ATX ATX Mid Tower Case ($64.98 @ Newegg)
Power Supply: Corsair RMx (2018) 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($144.99 @ Best Buy)
Total: $1994.89
Generated by PCPartPicker 2020-10-12 15:10 EDT-0400
if you want to be serious you probably aren’t getting a 3080 till 2021.
The problem is I work from home and my craptop is literally falling apart. Keys are coming off, the battery won't charge past 1%, and it randomly shuts down (presumably due to power) even when plugged in. I have to replace it soon or I can't work effectively. It's an Alienware 18, and dell wants $150-$200 to replace the 'board' that holds the keyboards (not labor, just the part) and another $200 to replace the battery. I can't stomach paying $400 to keep an 8 or 9-year-old laptop on life support. It literally has dual 280Ms, and they were epic when I bought it.
Thanks! I have survived off half a terabyte of storage for ages so I probably won't need 4.5 TB. I put the new cash into a beastly (as I understand it; when I built PCs AMD was a joke) processor that'll be out November 5th. Does this look like a pretty solid build?
I get it, Im just letting you know you probably arent going to be able to get a 3080 until 2021.
Well that stinks. TECHNICALLY I could buy it without the video card and plug in the card once they're available, right? A top-notch processor should have no problems with League of Legends on 1080p and zoom calls, right?
