I want to fit Liquid Cooling in my Corsair Spec-02 Case.
CowEater43
Commendable
Jul 15, 2016
I want to put water cooling into my Corsair SPEC-02 but I'm hearing mixed reviews about what fits and what doesn't. I would like to know all water coolers that fit in my case from any brand. Thanks for the help with this issue. Thanks.
Unfortunately, the case will not support our H105 cooler. There's just isn't enough clearance on top to support 240mm AIO cooler, more so the H105 which is a thicker rad compared to an H100i/H100i V2. There's probably a work around, but that will require some modification. Best is to get a 120mm AIO cooler, like an H80i/H75/H60. Those can be mounted on the rear with no problem.
The Water cooler i was going to go with is The Corsair H105 and people say it fits but some also say i doesn't. If you have any suggestions on what will work for my Spec-02 case Air or Water, That would help me a lot. Thanks for the quick response!
Did you try googling to see if anyone has issues with that cooler and case combo?
My suggestion is to keep searching yourself. Any closed loop water cooling system will suffice really. They all preform very well. Not like a custom loop, but again they will be enough.
Either find the exact measurements of the spot you want to put it in your case and look up the same detail for the cooler.
A thing that may be a problem is that some people need to rotate the reservoir/heatsink because it sometimes does bulge on the sides.
