[SOLVED] i want to upgrade my pc advice for components?
Jan 9, 2022
Hello i have a 8 years pc i have upgrade some parts like gpu and storage and the power supply but i want to upgrade cpu motherboard and ram and the power supply if needed. I use my pc for work, gaming (mostly modded minecraft) and other AAA games, recording videos , coding . i dont play to upgrade gpu any time soon and for the cpu i want to last me for an other 5-10 years in terms of use.
Current pc specs
Processor : Intel Core i5 4570 @ 3.20GHz
Graphics card : Nvidia GTX 1060 6gb
Monitor : 2 LG ULTRAGEAR (1920x1080@144Hz)
RAM : 16.0GB Dual-Channel DDR3 1600MHZ Crucial
Power Supply : Corsair CV650 Watt
Additional info:
parts that needs upgrade : cpu, ram, motherboard ,psu if needed
In terms of bugdet dont go above 1000 euros , 1150 usd
i dont care about overclocking
ram preferably 32gb
in terms of gaming am fine with running games at 1920x1080 60 or 144Hz
I would do this and keep the 1060 6gb card while you look for a new card if you cannot get enough fps with the 1060 6gb. Can sell your old computer as well;
PCPartPicker Part List
CPU: Intel Core i5-12400F 2.5 GHz 6-Core Processor (€190.94 @ Caseking)
CPU Cooler: Noctua NH-U12S redux 70.75 CFM CPU Cooler (€51.90 @ Alza)
Motherboard: MSI PRO Z690-A DDR4 ATX LGA1700 Motherboard (€196.40 @ Amazon Deutschland)
Memory: G.Skill Ripjaws V 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory (€157.90 @ Alza)
Storage: Western Digital Blue SN550 1 TB M.2-2280 NVME Solid State Drive (€88.86 @ Mindfactory)
Case: BitFenix Nova Mesh ATX Mid Tower Case...
Current pc specs
Additional info:
ram preferably 32gb
What country are you located and what computer case do you currently have?
If you dont plan on upgrading the graphics card the new i5 12400f should be just fine and even if you do in the future it should still be pretty good for years to come. The H610 and B660 series motherboards should be coming out in a week or two and just get the fastest ram the motherboard supports. If you don't want to wait for the new cheaper motherboards you will have to pick up a z690 mobo for atleast $200 which really isnt worth it if your not going to overclock. Then again if your budget is $1150 You can go all out with a z690 mobo and a $300 kit of ddr5 ram and the i5 12400f for now since thats all you need for that graphics card. You would have the ability to throw in an unlocked i5 or i7 in the future if you ever choose to.
Reactions: Why_Me
Case: BitFenix Nova Mesh ATX Mid Tower Case (€58.42 @ Amazon Deutschland)
Power Supply: Corsair RMx (2018) 750 W 80+ Gold Certified Fully Modular ATX Power Supply (€98.90 @ Alza)
Total: €843.32
Generated by PCPartPicker 2022-01-10 18:43 CET+0100
Reactions: Why_Me
https://www.visionstudio.gr/prodinf...fined&pmanuf=undefined&sort=undefined&step=13
Phanteks Eclipse P400A Mid Tower €94.98
Corsair TX650M 80+ Gold Semi Modular Power Supply €84,20
https://www.gatoulis.gr/product/asus_prime_b660m_a_d474
Asus Prime B660M-A D4 €151,40
https://mytechbox.gr/product/intel-cpu-core-i5-12400f-bx8071512400f/
Intel Core i5-12400F €198,19
https://www.priveshop.gr/product/11...FREEZER-34-ESPORTS-DUO-CPU-COOLER-ACFRE00061A
Arctic Freezer 34 eSports Duo CPU Cooler €38.05
https://www.arctic.de/us/LGA1700-Mounting-Kit-Freezer-34-black/MPSAS00892A
LGA 1700 Mounting Kit - Freezer 34
G.Skill Aegis 32GB (2x16GB) DDR4 3200MHz CL16 €107.11
https://gxstore.gr/product/western-digital-blue-sn550-nvme-ssd-1-0tb-m-2-wds100t2b0c/
WD Blue SN550 1TB M.2 NVMe SSD €93,56
Total: €767.49
https://phanteks.com/Eclipse-P400A.html
Reactions: helper800
Latest posts
