i want to vertical mount my GPU what will i need for this?
fireangel1996
97
I'm going to be getting a case that you can vertically put in a GPU on it, what will I need to do this, I have never done this before and think it will be awesome :} the card will be a MSI GTX 1080 TI
will this cable
EZDIY NEW PCI Express 16x Flexible Cable Card Extension Port Adapter High Speed Riser Card-25cm
with this case
Thermaltake View 21 Dual Tempered Glass ATX Tt LCS Certified black Gaming Mid Tower Computer Case Cases CA-1I3-00M1WN-00
and this GPU work well togeather?
MSI GTX 1080 TI GAMING X Video Graphic Cards
or should I get this case
Thermaltake View 27 Black Edition Gull Wing Window SPCC ATX Mid Tower Tt LCS Certified Computer Chassis with Red LED Riing Fan CA-1G7-00M1WN-02
It should work fine however I'm not entirely sure how to mount it vertically above the SSD slots if that's what your planning.
If you want to vertically mount a GPU, get a case which is designed to vertically mount the GPU's. My case has everything turned 90 degrees, which faces the PCIe slots vertically, and all I have to do is mount the GPU like any other. In such a position, the GPU hangs a lot more naturally, and the weight of the GPU won't cause any sag.
If the case you are buying is turned vertically, then you don't have to do anything special. Just follow the directions the case gives you.
Edit: the cases you are looking at are not designed for vertical GPU's. Here is an example of one that is:
https://www.newegg.com/Product/Product.aspx?Item=N82E16811163263&ignorebbr=1&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC-_-pla-_-Cases+%28Computer+Cases+-+ATX+Form%29-_-N82E16811163263&gclid=CjwKCAjwgvfOBRB7EiwAeP7ehg2Hlu1iVkWa_2U93LbpxX7VbbhvlasoNa_4En4zs5puAYdx8cygvRoCR_QQAvD_BwE&gclsrc=aw.ds
You'll find that SilverStone offers quite a few of them.
well the Thermaltake View 27 Black Edition Gull Wing Window SPCC ATX Mid Tower Tt LCS Certified Computer Chassis with Red LED Riing Fan CA-1G7-00M1WN-02
has a spot to do vertical , was wondering if it was a good case
I found what you are talking about. It's not what I was talking about. They are calling the type you are looking at a "Floating GPU". It should come with everything you need in the case.
https://www.newegg.com/Product/Product.aspx?Item=9SIA9N65Z52891&cm_re=Thermaltake_View_27_Black_Edition_Gull_Wing_Window_SPCC_ATX_Mid_Tower_Tt_LCS_Certified_Computer_Chassis_with_Red_LED_Riing_Fan_CA-1G7-00M1WN-02-_-1W8-00JK-00019-_-Product
It might look cool, but the SilverStone 90 degree cases should have better air flow (tests in the past showed this). If you want a quiet case, check out the link I gave earlier with the SilverStone. The one you are looking at should work fine, however. It would look nice too. It's likely noisier than most.
the link don't work Thank you for visiting Newegg.com. We are truly sorry for any inconvenience but we are currently experiencing problems on our server. Please try again at a later time.
If you have any questions, please visit our FAQs or simply contact us and our helpful staff will alleviate any concerns you may have.
Yeah, it appears Newegg is having technical difficulties. I had the same issue when I went back to revisit their site.
