Question I was cable managing for my first build (bought recently)
Apr 12, 2019
4
I was cable managing for my build and when i finally finished. i tested my pc to see if it would post and it turned on all fans were spinning rgbs on and then started smelling smoke and it turned off by it self need help is it fixable?
Specs
16 gb (2 sticks/hyperx)
240L liquid cooler
1050 ti gc
i7-6700k
750 powerspec ( i suspect is the problem)
Apr 12, 2019
4
Also i looked around saw everything plugged in as it was before, yes this pc did work before, ran games with no problems and today cable managed and it turned on fine then shut off abruptly
Apr 12, 2019
77
5
45
4
Try removing the PSU and test it with the paperclip test (where you turn it on without connecting it to the motherboard) and if you can smell smoke coming from it then the PSU is your problem.
