Question I was using my computer normally when suddenly my Hard Drive disappeared
supremekaiqc
Commendable
Feb 11, 2018
35
Is there any solution other than its broken and i need a new one?
im on a laptop using ssd + a 2tb hard rive i bought from amazon like 3-4 years ago
the hard drive was on D: but now theres just C and D is gone. any solutions?
also my laptop takes longer to boot since the drive stopped working if that can help
joeacejr15
86
4
545
Okay so your C drive is (im assuming) the solid state drive and the D drive (assuming) is the mechanical hard drive. Can you still start up the laptop alright? Your machine should not take longer to start up because of a failed game drive, or whatever the D drive was.
In terms of resolutions, if there was important data on the D drive, you could spend a few hundred dollars to try to have somebody recover the data, but maybe this is the lesson that you NEED an online backup. Backblaze is 6 dollars a month, or $60 per year for unlimited data backup. Watch this video to learn more about it.
View: https://www.youtube.com/watch?v=A9KDKH-a8yo
popatim
Next step is to check the and see if it's listed int he bios,
if you can feel it spinning or hear it clickiing away.
no spin is usually a power issue
clicking away usually means the heads can no longer read the platters.
Spinning without clicking away then i would try a new Sata cable.
supremekaiqc
Commendable
Feb 11, 2018
35
im on a laptop, everytime i would boot pc or just randomly when i was using the hdd I would hear a little noise. now I just dont hear it anymore
I checked the bios, it says none at the hdd1 it literally says no drive
popatim
If you have a friend with an external drive dock then you could have them check the drive.
You could also use a PC's internal Sata & Power connector to test with but I prefer testing drives externally. Sata Laptop & Desktop drives use the same connectors thankfully.
For laptop drives you only need something like this: https://www.amazon.com/Sabrent-2-5-Inch-Adapter-Optimized-EC-SSHD/dp/B011M8YACM
Desktop drives need more power and then a Dock comes in handy (they also fit laptop drives)
https://www.amazon.com/s?k=usb+drive+dock&rh=p_85:2470955011&dc&qid=1588016753
