I would like to know how to rearrange the 24pin connectors of a antec psu to work with a 16 pin fujitsu motherboard.
HitmanReginald
99
Hi, im looking for a detailed step by step guide on how to rearrange the pins correctly to work with my pacific motherboard.
I don't know how to even undo the pins, or what i need to know to rearrange them properly.
In that case, you will probably need to buy either a converter or a power supply with the correct pins for that motherboard.
Im referring to the 16pin power supply socket.
The 16pins on my motherboard are in a different order to the first 16 pins of the 24pin psu.
