Question I would like to upgrade some parts, because i don't know which are compatible with my motherboard
Dec 31, 2022
4
My PC has a motherboard by Lenovo and the model name is Sharkbay 31900058 STD
chip set is intel.
Can someone please list a compatible:
. Compatible GPU (really good one)
. Compatible CPU
Please can the Parts be the best as possible but both under £500=$604.90=563.92
it would be much apricated thx.
My current parts:
GPU= GT 705
CPU= INTEL i3-4160 CPU
Dec 31, 2022
4
I think it is around 150-250W
My PC that i currently own is:
H30-50 Desktop (Lenovo) - Type 90B8
you can go on the Lenovo website to check
geofelt
There are three constraints:
Your case requires a low profile graphics card.
The card must be half length.
Measure the length available in your case. 7" will fit some cards.
https://www.newegg.com/gigabyte-geforce-gtx-1050-ti-gv-n105toc-4gl/p/1FT-000A-00530?Item=9SIARA8J9X6864&quicklink=true
The card can not need aux power 75w max.
Probably the best would be a GTX1050 or GTX1050ti that is not factory overclocked and will run on slot power only.
FWIW here are some passmark performance numbers:
GT705 352 29w
GT1030 2511 32w
GTX1050 5058 75w
GTX1050ti 6298 75w
Changing out the psu might be possible.
DSzymborski
Yeah, as Geofelt notes, there are lots of better GPUs out there, but none better than a GT 1030 that satisfy the requirements of being able to fit in a small form-factor case and run on a very low-end basic office power supply. You may need to a new motherboard to meaningfully upgrade the power supply if you want a higher-end GPU; you'd have to check and see if there's any indication that the motherboard uses a standard PSU.
Honestly, I think you're going to be wasting any money you dump into this system. 10-year-old office prebuilt PCs don't make good upgrade candidates. To make a significant upgrade in performance and use case, you'd basically be replacing everything anyway. Use your money on a new build.
Dec 31, 2022
4
So the GTX 1050TI is compatible with my motherboard? BUT, i would need to check:
. Check the space available
*I am getting a new build soon but i will have to change the gpu in my current old office build cause i cant really play on anything else at the moment.
