citakultura :
Hello! Whats the max temperature for i3-8350k cpu ? ... cpu hit max 60 degree, is it normal ? ... cant find any information about it, ... looking for answer ...
On behalf of Tom's Moderator Team, welcome aboard!
At the top of all our Forums are "Stickies" which are informative Threads permanently "stuck" in place, so they're always available as quick referrence materials for everyone's benefit. Near the top of our CPU's Forum you'll se this Sticky:
Intel Temperature Guide -
http://www.tomshardware.com/forum/id-1800828/intel-temperature-guide.html
You should give it a read.
Although most processors Throttle at 100°C (212°F), it’s not advisable to run your CPU near it's thermal limit, just as common sense tells you not to run a vehicle with the temperature gauge pegged in the red "hot" zone. If your hottest Core is near it’s specified Tj Max Throttle temperature, then your CPU is already too hot.
The consensus among well informed and highly experienced system builders, overclockers and reviewers, is that cooler is better for ultimate stability, performance and longevity. Experts all agree that it's prudent to observe a reasonable thermal margin below Tj Max. So regardless of environmental conditions, hardware configurations, workloads or any other variables,
Core temperatures above 85°C aren't recommended.
Here's the operating range for Core temperature:
Core temperatures below 80°C are preferred.
Core temperatures increase and decrease with Ambient temperature.
Once again, welcome aboard!
CT
