[SOLVED] i5 10600KF DIY project
Jul 17, 2021
6
Will this work well together? Over budget but opinions on something better welcome.
Montech fighter 500 ATX mid-tower $58.99
Corsair Hydro H60 AIO Liquid CPU cooler $79.99
Aresgame P.W. 650W 80+ Bronze AGV650 $45.89
Nvidia GeForce RTX 3060 Ti $399 when it gets back in stock
i5-10600KF desktop pc $199.99
Asus TUF B560m LGA 1200 Micro ATX $149.99
Patroit Viper 4 blackout DDR4 4400MHz 8GBx2 $124.99
Samsung (MZ-V8V1T0B/AM) 980 SSD 1TB - M.2 NVMe $119.99
Thanks for your help.
Don't cheap out on the power supply. Super high clock speed RAM does not have a significant performance benefit. Save some money on slower RAM (3200) and use that money for a better power supply.
Be careful with reviews from purchasers at places like Amazon etc. They'll give 5 stars just because it shipped fast, arrived in good shape and works. Very few will get back into that review and change it when it dies or blows up the pc 6 months later, since they have forgotten all about it.
Instead, they come here, ask why their pc doesn't work, and often as not ppl tell them to get a better psu and hopefully it hadn't done any irreparable damage to other components. Amazon looks good because of the initial high rating, we don't look good because we tell you you were mistaken and now need to spend more money you don't have.
Which is why most of us are all to happy when ppl Ask first, purchase later. Everybody wins. You may spend more than you want to initially, but the chances of having to spend even more on repairs drop drastically.
Psu- really bad.
Ram- way too high priced, very little value for Intel, 2933/3200 is plenty, cheaper, better value especially considering 4400MHz is not supported on that motherboard chipset with a 10th Gen cpu. Requires an 11th gen cpu to unlock ram tables for OC.
Cooler is fine for moderate use, high overclocks and max cpu usage will stress it. An air cooler such as the CM hyper212 evo has identical performance overall, but a better option, cheaper than the aio would be the Arctic esports duo, it's quieter as well as better performance.
Being Intel, might want to consider the 10700 instead. Better performance than the 10600kf, has an igpu, so isn't reliant on the dgpu for video output. With a B560 motherboard, there's no cpu OC anyway, so paying extra for a K varient that can't be oc'd offers no real value.
Reactions: Simg
Better VRM's if you don't need the wifi.
https://www.newegg.com/p/N82E16813144396
MSI MAG B560M BAZOOKA $139.99
Save on the SSD.
https://www.amazon.com/PNY-CS2130-Internal-Solid-State/dp/B0869B4Q66/
PNY CS2130 1TB M.2 PCIe NVMe Gen3 x4 Internal SSD $109.99
Better psu.
https://www.newegg.com/super-flower-leadex-iii-bronze-sf-650r14he-650w/p/1HU-024C-00017
Super Flower Leadex III Bronze PRO 650W 80+ Bronze Modular Power Supply $69.99
Unlike Ryzen cpu's, Intel 10/11 gen aren't nearly as memory dependent. 3200Mhz ftw.
https://www.amazon.com/Crucial-Ballistix-Desktop-Gaming-BL2K8G32C16U4B/dp/B083TRRT16/
Crucial Ballistix DDR4 3200MHz 16GB (8GBx2) CL16 $87.99
I wouldn't recommend that Montech case to anyone but my worst enemies.
https://www.newegg.com/white-fractal-design-focus-g-series-atx-mid-tower/p/N82E16811352067
Fractal Design Focus G White ATX Mid Tower Computer Case $49.99
Exhaust fan for that case.
https://www.amazon.com/Kingwin-CF-012LB-Efficient-Excellent-Ventilation/dp/B002YFP8BK/
Kingwin 120mm Case Fan $4.99
https://www.msi.com/Motherboard/MAG-B560M-BAZOOKA
Reactions: Simg
Granted this cpu is $39 more but it does a few things that the 10 gen cpu in your build doesn't such as allow for use of the top NVMe SSD slot not to mention it gives you better performance.
https://www.ebay.com/itm/203371799302
Intel Core i5-11400F $238.99
https://www.guru3d.com/articles-pages/intel-core-i5-11400f-processor-review,1.html
Reactions: Simg
