Hello, I have recently build a new PC, but I am unsure whether my CPU temperatures are ok?
Here is my spec:
CPU: i5-12600k
MOBO: Asus Prime B660 Plus D4
CPU cooler: arctic freezer 34
GPU: RTX 3060 Ti
Here are my temperatures after 2-3 hours of playing Lost Ark while in game:
View: https://imgur.com/ovUVUiI
They are between 50-60 on average with the highest of 75 degrees. Also when I touch the transparent side panel it is warm on the area of where the cpu cooler is, other areas of the panel are cold.
When I was mounting cpu cooler I've noticed airflow arrows, perhaps it would be also nice if you can see whether I have mounted it correctly. I have drawn arrows as they are barely visible on the image.
View: https://imgur.com/Jkj1Puc
I will appreciate all the help.
Here is my spec:
CPU: i5-12600k
GPU: RTX 3060 Ti
