HI
Just made a new build and everything is going well but my CPU sometimes hovers around 75-80 degrees with spikes upto 95, even tho it's only <1 second it does spike that high. Is this normal/damaging in the long run ?
My setup:
Mobo: B760m Aorus elite AX
CPU: i5-13600KF
GPU: Radeon RX 6950 XT
Case: be quiet! Pure Base 500 windowed midi-tower
RAM: Kingston 32GB DDR5 x2
Fans/cooler:
1x 140 mm Pure Wings 2 at the back and 2x 140 mm Pure Wings 2 in the front
cpu kooler: PA 120 chroma SE, I heard nothing but good reviews / info about this cooler so maybe it's an airflow problem?
idle temps vs under heavy load(lost ark + ld player):
Temps - no clue why I can't add images directly
Additional info:
- I do have a widescreen 1440p monitor + 2 regular monitors so when playing intensive games on ultra the GPU also hovers around 80 degrees with the hotspot around 100
- My case is under my desk, so it's fairly open not in an enclosed space, only the right side is close to my deskcabins
- bios etc is default I only enabled the XMP setting to reach my ram speed
Anything I could do to lower the temps ?
My setup:
CPU: i5-13600KF
Fans/cooler:
Additional info:
