Question i5 14600k with Asrock B760m pro rs/d4 Undervolt
Oct 23, 2024
Hello,
I have a system with these specs:
Intel core i5 14600k
NZXT Kraken x63 (4x140mm fans push-pull)
Asrock B760m pro rs/d4 (Latest Bios Microcode 0x12B)
G skill ripjaws 32gb@3200mhz (4x8gb)
Seasonic focus gx atx 3.0 850w
RTX 3060ti
All bios settings are on default, except IA VR Voltage Limit set at 1.4
Everything is stable and i get a multi core score in Cinebench R23 of 24130 and with a 10min run i get max temps of 77 °C
I would like to know if i would be able to undervolt my cpu with this motherboard and which way is the correct one?
Thanks in advance
Afaik, all motherboards can undervolt.
For a more trial-until-error method you can download Intel XTU and undervolt from there so you don't have to reboot your system to change the offset each time. After you find a stable offset you can uninstall XTU and go into the bios to apply the offset there (you can just set XTU to launch on startup and apply the offset, but I like to avoid programs doing that).
Thanks a lot
Why do you think you need to mess with undervolting?
The thing is that since 2017 i had ryzen systems and undervolting always seemed to improve thermals, power consumption and gave a little bit of performance, both on cpu and gpu.
But i'm not that experienced with the latest intel generations that's why i asked.
I built this pc with an i5 12400 two months ago and some days ago i upgraded to 14600k but i cannot find the correct way to do it because of CEP and other factors.
Is it not worth it? 😀
Latest posts
