I5-2400 Temperature Problems
mainanonlinetea2
16
I Just Buy INTEL CORE i5 2400 @3.10Ghz
And I Try To Play GTA IV On Medium Quality But Sometimes My System Just ShutDown Because The Processor Is Overheating
i Try To Change My Thermal paste but The Result Is Same
MY SPEC
INTEL i5 2400 @3.10 (34C-95C)Stock Cooler
MSI RX 460 4GB OC Edition
ASROCK H61M-DGS
LG 20MP38HQ 1440X900@60Hz
Are you absolutely sure that it's the CPU that's overheating and not something else going wrong? Are you absolutely sure that the cooler is seated correctly and that the thermal paste is installed correctly? Are you sure that the fan is working properly and the cooler isn't full of dust?
Just Looking Fan Cooler And A Cable Just Stuck To The Fan Thx
