Approximate Purchase Date: (this week)
Budget Range: (e.g.: $900-$1500) Before Rebates
System Usage from Most to Least Important: (must be a stable office computer, then gaming)
Parts Not Required: (e.g.: keyboard, mouse, monitor, speakers, OS)
Preferred Website(s) for Parts: no preference
Country of Origin: US
Parts Preferences: no preference
Overclocking: Maybe
SLI or Crossfire: No
Monitor Resolution: not sure. Will probably be buying 24-27” monitor in next 6 months.
Additional Comments: (I need it to be stable. This is a “work” computer that will be used for gaming as well. I will be running XP or Windows 7. I’d appreciate it if someone could double-check my memory choice. I think these will work (from the threads I’ve been reading), but want to make sure. This is my first home-build, so I’m a bit nervous that I’m forgetting something. Thank you for any help or advice.)
I'm missing an optical drive and a 1TB secondary drive - any simple suggestions here?
Case:
Antec Nine Hundred Two V3 Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129097&Tpk=antec%20902%20v3
Motherboard:
ASUS P8P67 PRO (REV 3.0) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131703&cm_re=ASUS_P8P67_PRO_B3-_-13-131-703-_-Product
CPU:
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) 4 x 256KB L2 Cache 6MB L3 Cache LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072&cm_re=i5_2500k-_-19-115-072-_-Product
MEMORY:
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314&Tpk=F3-12800CL9D-8GBRL
Boot Drive:
Intel 320 Series SSDSA2CW120G3K5 2.5" 120GB SATA II MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820167050&cm_re=intel_320_120gb-_-20-167-050-_-Product
GPU:
Sapphire 100312SR Radeon HD 6950 Video Card - 2GB, GDDR5, PCIe, mini-Display Port, HDMI, Dual DVI
http://www.tigerdirect.com/applications/searchtools/item-Details.asp?EdpNo=7073913&sku=A271-6950
PSU:
CORSAIR Enthusiast Series TX650 V2 650W ATX12V v2.31/ EPS12V v2.92 80 PLUS
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020&Tpk=Corsair%20650TXV2
Overclocking: Maybe
Case:
Motherboard:
CPU:
MEMORY:
Boot Drive:
GPU:
PSU:
