Hi all,
Need your input on the following, please see below:
I was running Windows 7 64-bit and was getting 80-90% CPU load (confirming with using task manager) with 40-55% GPU load (Using GPU-Z) in BF4 online in 64-player maps. Needless to say I wasn't happy as I just got SLI a-going with my 780s recently and that cost me a leg and a arm.
So, I did some researching and heard to plunge into Windows 8.1 to get better performance for SLI. I went ahead and made the plunge in Windows 8.1 Home 64-Bit. It was incredibly easy install and one of the smoothest I've done. So now, in GPU-Z I'm pulling up in BF with 100% CPU load all the time with 60-78% max GPU load. So definitely better than Windows 7, but is clear that my CPU is holding my GPUs back...
I'm running a i5 2500k overclocked to 4.8GHZ confirmed while running CPU-Z and task manager (performance tab). I'm using the Asrock Z77 Extreme4 board.
Any suggestions as to what I should do? Is it worth upgrading to Ivy since that what my board is made for? I got Sandy at the time because it was a great deal and from research I've seen is that the jump to Ivy is not super significant, but if I can get some feedback that it WOULD be for my SLI performance, then I'll do it. I'm quite surprised that my Sandy clocked at 4.8GHZ isn't holding up?
Thanks all.
Thanks all.
