i5 4590 temps
Chris 2180
64
Hello, I have noticed that while doing simple activities such as web browsing my i5 4590 can reach up to 45c. Is this normal for the stock heatsink?
specs:
i5 4590
r9 280
8 gb ram
45°C while browsing web/ light programs is normal, how hot does it get under max load? If it's 70° C or lower you are fine
If you are worried about temps you can grab a cheap aftermarket cooler for 20-$30 like the hyper 212 Evo or cryorig h7.
Without an overclock my 4690k was at about 50°C under load. When it would be 70° C with the stock heatsink
Yes that is also something I wanted to bring up, I have noticed that my temperatures sometimes rise to max of 75c, but never above while gaming. Is this something that needs to be addressed?
