Hi all, I've finally got around to my first attempt at overclocking, and am having some trouble.
I've set the clock to 4.5GHz at 1.15V and everything seems stable, however the CPU is not actually running at 4.5GHz. Both Prime95 and AIDA64 will only run the CPU at exactly 4.0GHz, and during boot it peaks at exactly 4.2GHz. These speeds are across all 4 cores. Setting the multiplier to anything above 4.2GHz doesn't change the speed, it will never exceed 4.2GHz, or 4.0 on Prime or AIDA.
During overclocking all I did was change clock speed, change voltage to manual and disable Intel turbo boost. Have I missed something?
Any advice would be appreciated, thanks
SPECS:
i5-4670k
Gigabyte Z87X-D3H
Noctua NH-D15
Corsair CX750M Bronze
Kingston Hyper X 2x4Gb 1600 MHz
Gigabyte GTX770 Windforce 2gb
Samsung 850EVO 500gb
SPECS:
i5-4670k
Gigabyte Z87X-D3H
Noctua NH-D15
