i5 4670k overclocking help
Mrjellop
67
so i have a silverstone argo 1 and at 3.9 or 4.0ghz its max is 91C Max load on prime95
i was wondering what are some stable temp and should i try 4.1ghz?
but average around 68-70C
Also what temperature does ur system shutdown because of hot heat because I am scaryed if I let prime 95 test while I sleep it could go 100C and melt my CPU
Ahh I want to overclock ATLEAST 4.0ghz but it says 3.990ghz is there a way I can add that 10 extra so it be 4.0ghz no 3.99ghz I am using gigabyte motherboard and I set everything to auto expect my clock multipler to 4.0ghz is there a way I can lower this temp?
