i5 4690 CPU temps
XFA24
330
just so you know, i've read the pinned threads about cpu temperatures but im still quite confused..
currently im using a stock cooler, and I play watch dogs on medium settings
I get CPU temperatures ranging from 65-70 degrees using CPUID
are these temperatures safe?
now when I mean safe, I mean that there is no damage to be sustained by the processor
thanks in advance!
Yeah, that means your 60-65C temps you are getting would only be 52-57C if you were in a 22C environment like above. You're still good.
Yes, safe....
4th Generation 22 Nanometer: 4790K (TDP 88W / Idle 2W)
Standard Ambient = 22C
Tcase (CPU temp) = 74C
CPU / Core offset + 5C
Tjunction (Core temp) = 79C
Tj Max (Throttle temp) = 100C
The Core temperatures above show that mid 70's are safe.
(from: http://www.tomshardware.com/forum/id-1800828/intel-temperature-guide.html)
ohh okay thanks
but the ambient temperature here in my place is 30 degrees, does it matter?
