Hello all, thanks for taking the time to read this.
I have been working to find a stable OC for my i5 4690k @3.8ghz. At idle, it sits between 30-40c. While pushing the speed up to 4.0ghz with stock voltage, my CPU was reaching temps of up to 83c on all 4 cores within the first two minutes of Prime95 stress testing.
As far as cooling is concerned, I have a Cryorig H7 Quad Lumi, with comes with a front intake fan for the heatsink, three Corsair LL120s in the top and rear of my chassis, and two intake fans in the front. (If I have been researching correctly this should be more than adequate for a small and safe adventure in overclocking. The Quad lumi fan is hitting just about it's max rpm with these stress tests. To add, My gtx1080 OC has never exceeded 69c under heavy load. Ambient temp is around 21c.
My troubleshooting:
-Slightly loosened the heat sink....no temp change. Tightened it again....same.
-Replaced stock cryorig fan with one LL120......noooo dice
-Purchased another Cryorig PWM fan and placed it in the rear of the heat sink to pull some heat out, and force it though my rear fan........temp got knocked down only 2 to 3 degrees.
-Carefully re-installed the H7 Quad Lumi while being very conscious of correct thermal paste-application (pea-sized amount in center of CPU). I thought this step would do it because the paste got smeared around a bit when trying to sit the heat sink into the screw-holes during the initial installation.......of course this didn't make any change at all.
I can work my way around the hardware but I'm not as comfortable with the MSI BIOS, so maybe there is some type of solution there? I haven't changed anything in the BIOS however other than the CPU multiplier.
I see people getting 4.4ghz with safe temps out of this CPU with less cooling effort. Furthermore, consumer reviews show that most people who rock the H7 Quad Lumi are getting idle temps under 30c.
Once again i appreciate the time and any future responses or suggestions.
For the sake of my sanity and my bank account I hope am missing something patently obvious here.
My troubleshooting:
