Good evening,
it's been a long time now I have my CPU overclocked at 4.3 Ghz.
Recently I bought a new CPU cooler the D15 - Noctua (installed with double fans and used the Nocuta thermal paste)
I then clocked it up to 4.5 Ghz with a Core Voltage of 1.12V (stable).
But now comes the "problem" I've seen people posting their Core Voltages > 1.2V but with temps around 50°C and <30°C in Idle.
My Temps are around 35°C in Idle and around 60°C under full load and while playing and this with only 1.12V. I think i really got a good chip, but I really don't want to clock higher because I don't want to reach higher degrees then 60°C.
Do you have any advices where the temp "problem" could be or how to get lower temps? I was thinking of adding addtional and better case fans (2 in front and 1 at top), but I can't imagine it would get me lower temps.
Specs:
Motherboard: Asus maximus Ranger VII
CPU: i5 4690k
CPU Cooler: NH D15 - Noctua
Case Cooler: 1 unknown 120mm front , 1 unknown 120mm back
Specs:
CPU: i5 4690k
