First I hope you have a decent CPU cooler. If so then just change the multiplier and voltage. start at by changing the multiplier to 44 and the voltage to 1.21 volts and work from their, all chips are different you should be able to get 4.4 with that voltage. Download and run OCCT to make sure it's stable and not running hot.
