It depends firstly on the temperature inside the case and secondly on the ambient temperature outside the case.
In other words, you can only cool to a few degrees over the air temperature. If there is hot air surrounding your CPU, then the temperature you see is normal.
Describe your case, the ventilation, the PC locations and the room temperature in more detail before anyone can make a determination.
