i5 4690k temps high. Need help?!?
xConorHDx
50
Hi there,
I just built my second PC on Thursday, and after monitoring the temps of my i5 4690k for the last 2 and a half days they seem really high. Although there is lots of threads on here about this already I couldn't find one that matched my problems and wanted to ask myself with my issues to hopefully get a specific answer.
So, I'm running an i5 4690k at stock speed, with a cooler master hyper 212 evo as the cpu cooler. I have been experiencing idle temps of 35-40 degrees Celsius, I know that idle temps don't really matter as such, but then I've played some games to test and the only games I've played so far are Cs:s and Cs:go and I'm getting temps of 55-60 on Cs:s and 60-67 on Cs:go, as well as Cs:go crashing 3 times last night. Now I know that's not right and just wanted help to figure this out before I go further on in my pc's life. I was thinking of taking off the cpu cooler and thermal paste and reapplying and remounting. I used the Baggie technique to spread the thermal paste, which I done in my first build 2 years ago and was fine, but this time I was just going to do the pea method.
Anyways, any help is greatly appreciated as I haven't really been able to fully relax with this PC yet as I'm always checking temps and worried about it.
I'm running,
CPU: i5 4690k
Cooler: CM hyper 212 evo
Gpu: gigabyte Gtx 970 g1 gaming
Motherboard: asus Maximus VII hero
Ram: g.skill 16gb ddr3-1600
Psu: evga g2 750w
Os: windows 8.1 64bit
What was the error code when it crashed? A lot of posters claim that an AMD CPU will crash if it gets hotter than 67°C, but I've never seen that with an Intel CPU. They can throttle or shutdown, but they don't crash. My i5-4590 works very well at over 80°C (checked with Intel XTU) and it's stable; so are my other Intel processors.
A lot of the time temperature issues with the Hyper 212 result from people not tightening the center screw on the mounting bracket. Did you remember to do so? It would also be good for you to reseat the heatsink with some better thermal compound such as MX-4 or Céramique. AS5 is also pretty good but it just costs a lot more for the same quality stuff. And what is your ambient temperature? In addition to that, you can also go into your motherboard's UEFI BIOS and disable Asus Multicore Enhancement. I did so with my VII Hero and it shaved 5ºC off idle temp and 15ºC off 100% load temp (I have a 4790k).
OP meant that CS:GO crashed, not his computer. This is not nearly as severe as thermal throttling etc. Any CPU should be able to function over 80ºC, but high temperatures and loads may cause certain applications to crash, which is what happened here.
Ok, so I remembered that i hadnt tightened the center screw and have went and done so, i have booted up and entered bios and disabled Asus Multicore Enhancement, using real temp GT with just this page open, the temps are jumping around from 30ºC-36ºC, with load jumping around anywhere between 7%-20%. Where do i go from here? Do i test in counter strike again as the temps i was getting before shouldnt be happening to see if anything changes? If not reseat cooler and replace thermal compund? Or are there any programs that i can use? I tried prime95 the other day for approx 30 mins (I know not long...) with the temp highest 77ºC.
any help greatly appreciated!
If i run these, what am i looking for? How long do i run them or are they timed themselves? thanks
I've just played one game of cs:go with the highest temp reaching 61ºC, i still think this is quite high for a game that doesnt need a whole lot, what do you's reckon? The average temp was around 55-57ºC. Where do i go from here? Thanks
For stability testing I run RoG real Bench for 2 hours ... but for our purposes here, just run the benchmark which takes about 8 minutes.... use HWiNFO to get max core temps
http://rog.asus.com/file/?download=RealBench_v2.41.zip
Those temps don't sound all that concerning, not sure why temperatures would cause a program to crash. Bad coding or need for patches or updates maybe. A hot/overheated gpu could cause video to crash. Below 70 aren't high temps for an intel cpu at or near load. I just see a lot of concern and focus on temperatures which appear to have little to do with it. They're not high enough to cause thermal throttling, the pc isn't suffering bsod's. A single program not running properly is more or less to do with that program rather a major core component when the rest of the pc is operating normally.
Unless I'm mistaken and the pc itself is crashing and needs restarted, but like JackNaylorPE said that can be a stability issue based on any number of things from bios options to memory settings etc.
No it was CS:GO that was crashing i dont know why tbh, ive updated everything on my PC and just presumed that due to cs:go not being highly demanding it was running too hot, and that was what caused it too crash. The crashing isnt the main thing i posted for though, it was due to the temps, but thanks for reassuring me a bit. I think i'm going to remove the thermal compound and try doing the pea/rice technique instead of the spreading technique, as well as remounting the cpu cooler obviously. Nowheres open here today (Sunday) in Perth, Australia, neither tomorrow, so ill have a go again at reapplying the cooler master thermal compund, if still no change ill go tuesday and get arctic silver 5.
ill post back here if i get stuck, if anyone has anymore suggestions or tips/input, please, post them i would love to hear. Thanks, Conor!
The downside to P95 26.6 to my eyes is that it will produce temp measurements of a sort, certainly nothing you will ever experience again. I think the main reason why Intel as well as MoBo manufacturers recommend against it but also because it is totally useless for stability testing since you are not testing for stability with AVX and all the other instruction sets programmed into modern CPUs.
Also, because the temp results are unrealistic and not representative of anything you will ever experience outside P95, you wind up with an overclock that is unnecessarily lower than it otherwise could be.
When I'm overclocking, (let's say we want to have a maximum temp of 75C) I want get the highest stable overclock possible when doing any thing that might conceivably actually ever be run on a day to day or even occasional basis. So how can I best accomplish that ?
With P95, the max OC I can reach and stay under 75C is 4.6 Ghz ..... but I have not tested for stability at that speed using all the CPUs instruction sets.
But, using a suite of the most demanding and CPU intensive applications, running them all concurrently in a multitasking scenario and testing all CPU instruction sets, the max OC I can reach and stay under 75C is 4.8 Ghz
I still have P95 (latest version) in my toolbox..... I use it to set / cure TIM of a new build heating it up to 85C for a minute, letting it cool and repeating 4 or 5 times
Okay let's not get too far ahead of ourselves right now. OP is concerned about his CPU temperatures, and is running it at stock speeds. We need to first evaluate his CPU temperatures, because you can't do any overclocking if you get say 90ºC 100% load at stock speed. To do so we have to use a 100% steady-state workload. You can't do temperature tests at 50% load, there are just too many variables. Prime95 v26.6 provides the most stable, full load stress test that does not include AVX. You are referring to Prime95 v28.XX, which does include AVX. http://www.tomshardware.com/forum/id-1800828/intel-temperature-guide.html This is article is written by another forum member and is meant to help with CPU temperature issues.
2 days ago i reseated the cpu cooler as well as, reapplying the cooler master thermal paste and my idle temps are around 30-34ºC
I ran this test for 12 mins and got 0 errors as well as the highest temps were (using realtemp):
core 0: 63ºC
core 1: 65ºC
core 2: 66ºC
core 3: 62ºC
Right now it is 21ºC outside, but as i live in an apartment it is a bit warmer so maybe like 23-26ºC, are these results ok. I would like to overclock if possible in the next couple of weeks but wan to make sure that im safe to do so. Thanks everyone for their help so far.
Yes those are perfect temperatures, assuming that they were at 100% load on Prime95. You do have plenty of room to overclock. After applying an overclock your 100% load temperatures on Prime95 may exceed 80ºC (I don't recommend you test this), but that does not necessarily mean that you need to lower the overclock, as you're never really going to reach 100% load for an extended period of time with regular gaming or video rendering workloads. I think you should be able to push 4GHz as of right now, but you'll probably want to lower that as ambient temperature increases.
I ran this test and got these results:
Image Editing
108206
Time:79.293
Encoding
69871
Time:171.573
OpenCL
63941
KSamples/sec: 1530
Heavy Multitasking
59528
Time:164.292
System Score
62598
I'm not sure what these mean. Also I didnt know that Hwinfo was a program and didnt use that, i used realtemp, with the results as follows:
Core 0: 61ºC
Core 1: 61ºC
Core 2: 64ºC
Core 3: 62ºC
Any help to understand these results? Thanks
Ok thanks for that advice, when you say i should be able to push 4GHz do you mean 4GHz on the dot or over? I know it's hard to say as all processors are different, just want to make sure. Also i posted some Realbench results above, do you know what they mean? Thanks for your help!
Also ran furmark for 22 mins with no errors at 1920x1080 with 4x MSAA fullscreen, gpu got to 68ºC as the highest. CPU core 0: 59ºC core 1: 59ºC core 2: 60ºC core 3: 60ºC
So guys with the knowledge posted what does everyone reckon? System is all good? Am I ready to stop worrying and enjoy the PC? hahaha, if all is ok I will look up how to guides on how to overclock and such as this is something that interests me and would like to give a go as i didn't with my first build. Thanks for all the continued help to everyone who has posted on here! Conor
I personally don't use RealBench so I have no idea what those scores mean, but I know that it's meant to test the performance of your setup as a whole and isn't a diagnostic tool. The CPU and GPU stress test temperatures that you posted are more than optimal, and your components are fine. The high temperatures and crashes with CS that you faced at first are perhaps due to an incorrectly mounted heatsink and software issues, nothing to do with hardware. Your CPU and GPU are fine, and I'm not too sure why others recommended you test your GPU as there was no reason to. You don't need to worry about your system anymore as all the temperatures are looking good. If you're still a bit uneasy, download the Intel Processor Diagnostic tool and run a quick test. I'm sure you'll be fine.
You can't do temperature tests at 50% load, there are just too many variables. Prime95 v26.6 provides the most stable, full load stress test that does not include AVX. You are referring to Prime95 v28.XX, which does include AVX. http://www.tomshardware.com/forum/id-1800828/intel-temp... This is article is written by another forum member and is meant to help with CPU temperature issues.
No..... while 28.5 is very capable of destroying your CPU because when AVX and other instruction sets are called upon, voltage spikes 0.10, 0.13 and higher. However, 26.6 still puts on a CPU load that is greater than you can possibly achieve using any application based benchmark.
P95 26.6 - like testing your new 5,000 pound towing capacity pickup truck pulling a 7,500 pound load up 6%, 2 mile long grades, at 4,500 feet elevation in 85F weather
P95 28.5 - like testing your new 5,000 pound towing capacity pickup truck pulling a 10,000 pound load up 12%, 7 mile grades, at 12,000 feet elevation in 105F weather
Neither is representative of your new 5,000 pound towing capacity pickup truck towing the 3,500 pound boat you actually own over the hills between your house and the local marina at seal level.
To use another analogy, P95 28.5 is like being the last guy left on a dodgeball game and the other team is using a pitching machine sending baseballs at 150 mph. P95 26.6 is like being the last guy left on a dodgeball game and the other team is using a pitching machine using baseballs sending baseballs at 120 mph. RoG RB is like you're still the only one left but they have 4 guys each sending tennis balls at 98 mph at the same time and they keep moving the machines :). you'll get hit a lot more but it's no where near as dangerous.
What is the point of testing w/ 26.6 when:
a) It creates temps that no combination of programs you will actually ever use are capable of producing . If you are thinking, I want the highest OC I can get w/o my hottest core going above 78C, you unnecessarily limit your OC.
b) Your have a modern CPU w/ modern instruction sets that allow you to complete certain tasks at speeds which older CPUs are incapable. Yet, you are "testing your OC for stability" using a tool that does not include these instruction sets.
c) You can be P95 26.6 stable for 2 hours and then crash using the individual applications in RoG Real Bench. You therefore wind up with a CPU and OC that can run benchmarks but not real applications. And unless you are a competitive overclocker, we buy our machines so that the can run real applications.
I hit temps in the mid - high 70s at 4.6 Ghz (1.375 volts... > 1.5v peak) under RoG RB. With 26.6 I can easily hit temps which could shorten chip life ... with 28.5, I could possibly kill the CPU.
I'm not sure what these mean. Also I didn't know that Hwinfo was a program and didnt use that, i used realtemp, with the results as follows:
Core 0: 61ºC
Core 1: 61ºC
Core 2: 64ºC
Core 3: 62ºC
Well the reason you use HWiNFO is it makes all other utilities obsolete. No need to keep 8 utilities for measuring this, that and the other thing .... sensors only is the mode you wanna use here.... tho the tool is extremely useful.
http://www.hwinfo.com/
As for the relative usefulness of testing tools any question of "is this high" can not be answered if everyone is using different rulers ... if one is in cm and one in inches, we aren't going to get the same numbers.... A game is the most useless of choices as the load various continuously throughout the game. So for example.... getting 65C walking alone thru the woods might be 75C during a big battle with lots of characters. A game also isn't going to be very much fun if it constantly does the same thing over and over again.... watching your toon gallop on a horse really, really fast for 2 hours doesn't show us that your machine is stable when other animations are initiated or lighting changes, shadows etc....that's P95.
Now that we both are using the same ruler (RoG Real Bench) using the same scale of measurement for comparison purposes I can conclude that you are hotter than I'd expect. I got temps similar to yours at 4.5 Ghz. At stock speeds I am at 46 - 52C. Remember also that the 4690k is reported by anandtech to run 5 - 10C cooler than my 4770k.
As for diagnosing your crash problem, again.... a single function synthetic benchmark is useless here. Again I will use car analogy, you hear a sound and bring the car in and the mechanic can't find it.... but did ya remember perhaps to tell him that the sound occured while braking while in a cloverleaf getting onto a major highway. If the mechanic drove it down the road, stopped, turned around came back he wouldn't find it.... that's the p95 test..... doing the same thing over and over again. Sometimes it takes a combination of factors to create the conditions which create an instability. By multitasking 4 different applications using Open CL, AVX, SSE2 in a random multitasking environment, you are testing not only the CPU but how the CPU interacts with the system in a wide variety if ways.
As previously indicated, I have used P95 to set TIM by putting on a moderate "shot in the dark" OC and then cycling up to the mid 80s an back down to room temperature finishing with a 2 hour run. On several occasions I have had that same "shot in the dark" OC fail under RoG Real Bench....have passed 8 hours of Intel XTU and failed under RoG Real Bench. The 8 minute benchmark test has saved me days of wasted time as I have uncovered instabilities with it in minutes..... anything with P95 under 2 hours is non conclusive.
So... where are we at .... your 61 - 64 temps is a very tight band.... sounds more like average numbers than max recorded. Another reason to use HWiNFO (4 columns - current, min, max avg) .... usually the spread is 10C from lowest to highest....It gives ya a better idea as to whether the peak was a little burp or a routine thing.
Here's what I'd suggest. Go into your BIOS and find these settings, right click on them to move these to your "favorites" page, .... don't change any settings as yet ....Once done, go to the tools tab, OC Profiles and save these settings to profile 1 and label it "stock"... Hit F10 (save and exit) ..... Go back into BIOS and now make the following changes (in bold).....most will already be there.
AI Overclock Tuner = Auto
1-Core Ratio Limit = 42 (all others should automatically change with Sync all cores selected above)
Max. CPU Cache Ratio = Auto
Min. CPU Cache Ratio = Auto
Fully Manual Mode = Disabled
Core Voltage = Adaptive
Additional Turbo Mode CPU Core Voltage = 1.200
Core Cache Voltage = Adaptive
Additional Turbo Mode CPU Cache Voltage = Auto
Eventual CPU Input Voltage = 1.90
DRAM Voltage = Auto
Again, go to the tools tab, and save this profile in the next slot and label it "4200", save and exit
Run RoG Real Bench again..... if it passes the 8 minutes w/ decent temps, run the stress test for 2 hours.... if it passes, set AI Overclock Tuner to XMP and retest.
If we get that far come back and we'll see where we go from there.
Next, while it didn't suggest it for your problem at hand, I did tell ya up top there that if you wanted to test for GPU issues and go GPU overclocks, the tool for watching GPU temps is Furmark. GPU-Z, MSI AFterburner and Unigine valley (among others is also useful). In the meantime, if ya wanna play with that
http://www.guru3d.com/articles_pages/gigabyte_geforce_gtx_970_g1_gaming_review,26.html
With AfterBurner we applied:
Temp Target 80 Degrees C
GPU clock +150 MHz
Power limiter 112%
Mem clock +500 MHz
Volatge + 87Mv
FAN RPM default
First save the default settings in the 1st "save slot" . Then Input the above settings into Afterburner (except memory) , and apply.... run..Unigine Valley check temps with Afterburner...adjust clock up or down by 10 based upon your success. When ya fail go back down and save the stable settings. Now start playing with memory in same manner. You will find that some games are just too unstable ....BF4 is one.
If ya get this far. we'll pick up at this point next time.
I've used 26.6 and there are applications that definitely keep a CPU more busy. If a system has issues running 26.6, then it has been poorly assembled. Any system should be able to run 28.5 without issues (other than throttling if the cooler is not good enough). You won't kill an Intel CPU unless you apply too much voltage and run it for an extended period of time at it's thermal limit. In a different thread a member has an issue because his CPU throttles almost 100% of the time; that happens because the cooler no longer is making good contact. That also happens when systems are shipped; fixing the cooler resolves the issue and the CPU keeps on working.
