i5 4790k fan cooler
kriegsgott
37
Was wondering if the stock one is good enough fot overclocking or should I go ahead and get an aftermarket fan. Not looking for water cooled dont have the space for it but if anyome could reccomend some fan coolers or if the stock one will do the trick
Stock HSF (Heat Sink Fan) won't do the job for you. Depending upon your budget, Case, RAM you may consider these options:
Noctua NH-U14/12S or NH-D14/15
Cooler Master Hyper Evo 212
Corsair H100i (Closed loop cooling solution) You may consider it, even though it is not a air cooler but still good. From price over performance CM 212 Evo would be a good choice followed by Noctua.
