I5 7400 Average temps
Fox034
Hello everyone, I have the following configuration:
I5 7400 3.0mhz
Corsair H60
PSU Seasonic M12II-620 EVO
Ddr4 Corsair Vengeance 8gb 2400mhz x2
Mother Gigabyte Ga B250 Ds3h
MSI GTX 1070 8gb
Case Thermaltake Core v31
The problem is that in some games the temperature of the CPU is between 70 and 73c with the CPU load at 100%. It is normal? What temperatures are ideal for this CPU? Replace the thermal paste a few months ago. The gpu does not exceed 63c.
Completely normal. Max "safe" temp (according to Intel, who provides the warranty) is 100c. As long as you keep it under 100c you won't have any issues.
Forum member CompuTronix has a temperature guide sticked at the top of this section you can read if you'd like. If you're overclocking and increasing voltage (which you won't be with that CPU), you'll probably want to keep it under 80c instead.
