This first little paragraph is just to preface before I get to the question I'm asking. I started a thread last August when I overclocked my i5-7600k chip to 4.8GHz with a voltage of 1.375. Since then I've updated my BIOS which allowed for a little extra overclocking headroom. I managed to get my chip to 5.0GHz but I wasn't comfortable with the voltages required to reach that stable overclock which was 1.45 volts. So now with the BIOS update I'm able to get a stable 4.8GHz overclock with 1.34 volts. Although the voltages are lower than what I needed before the BIOS update to get a stable 4.8GHz overclock, my temps seem to be slightly higher (but only under full stress load). My temps are in the upper 70s when stress testing the CPU but never exceeded 80. They seem to stay at a pretty good range when gaming though, never exceeding 75c.
So my question is should I be worried about keeping my chip at 4.8GHz with a voltage of 1.34? I've heard some folks say that going above 1.35 volts is not ideal and others say that anything below 1.4 volts is fine. So I'm just wanting to get a second opinion and hear what any of your comments might be.
