i5 7600k - will fit on Asus b150m gaming pro motherboard?
Cheaviel
Will i5 7600k for on Asus b150m gaming pro motherboard ?
If not, will it for after some bios update ?
I know probably i5 6600 will fit but would like to get 7600 as itd coupe pounds dofference in price.
Thanks you in advance for help
yes the i5 7600 will work, but only after the bios is updated to 0601 or better
if you are buying new, and the bios is not up to that or better then it will not boot
The 7600k has a higher clock. By 300MHz if I remember correctly.
yeah 300mhz base higher, 100mhz boost higher, i kinda hate the fact that intel made their non k and k version of their processor have different clock now:/
