Hello!
I recently moved my gaming setup from my room into the living room and I don't have a cable long enough to use a LAN connection. I am currently using a WiFi adapter, but I encounter a lot of lag.
Anyways, I can't seem to settle on a MOBO and currently I have been watching the H370, Z370, and the B360.
I want the best MOBO for a budget no more than $170. Will the WiFi built into these MOBO's be enough for gaming? Or should I just buy a super long Ethernet cable and buy a cheaper board? Should I invest in a router?
Thank you all. Anyone's response will be appreciated.
Notes: Bluetooth is also a concern.
