Antec 300
Antec 650watt psu
i5
Coolermaster Hyper 212 Plus
GIGABYTE GA-P55-UD3R
G.SKILL Trident 4GB -F3-16000CL9D-4GBTD DDR3 2000 Timings 9 9 9 27
SAPPHIRE Radeon HD 4890 1GB (Not the vapor-x version)
WD Caviar Black 640 main drive
Seagate 1.5T
Lite On iHas124 CD/DVD Burner
Looking for a stable 3.6ghz overclock. I think I have things close but since I'm a newb I'd like your input. I'm prime stable on all three tests for an two hours each, haven't had time to go longer yet.
Temps are fine all in the 50's for max load. In CPUZ Core Voltage says 1.34V under load.
I've also ran memory tests and all seem to check out fine. Every once in awhile I get a BSOD on startup but it seems like it's only on cold bootup and it's very random even at that. I can't trace it down and it's driving me nuts.
Running the F2 BIOS because I'm a newb and am afraid to flash it.
CPU Clock ratio 18x
Advanced CPU core:
Turbo Boost Disabled
CPU Cores All
CPU Multi-threading Disabled
CPU Enhanced Halt C1E Disabled
C3/C6/C7 State Support Disabled
CPU Thermal Monitor Enabled
CPU EIST Function Disabled
Bi-Directional PROCHOT AUTO
QPI Clock Ratio x32
BCLK Frq 200
XMP Enabled
System Memory Multi 10
PCI Express Freq 101
CIA2 Disabled
CPU Clock Drive 900mV
PCI Express Clock Drive 900mV
CPU Clock Skew 0ps
DRAM Timing Selectable Quick
Channel Interleaving Auto
Rank Interleaving Auto
CAS Latency Time 9
tRCD 9
tRP 9
tRAS 27
All other Ram settings on Auto
Load Line Calibration Enabled
CPU Vcore 1.350
QPI/Vtt Voltage 1.350V
PCH Core Auto
CPU PLL 1.900V
DRAM Voltage 1.620V
DRAM Term AUTO
Ch-A Data VRef Auto
Ch-B Data VRef Auto
Ch-A Address VRef Auto
Ch-B Address VRef Auto
Isochronous Support Enabled
Virtualization Tech Disabled
How do things look? What should I change? I know I need to run prime95 for longer, my main concern is the strange cold boot issue and also not wanting to overvolt anything since I'm pretty sure I've got the dreaded foxcon socket.
Only other issue I've noticed is Crysis froze a couple times and ate all my RAM a couple times but I think that's an issue with that pig of a game as apposed to the setup.
So far this thing rocks, I just want to get everything where it needs to be. I appreciate any advice you can give since I'm not 100% sure what all the settings mean and am still learning.
Antec 650watt psu
i5
Seagate 1.5T
CPU Clock ratio 18x
Advanced CPU core:
CPU Cores All
QPI Clock Ratio x32
BCLK Frq 200
XMP Enabled
CIA2 Disabled
CPU Clock Skew 0ps
CAS Latency Time 9
tRCD 9
tRP 9
tRAS 27
CPU Vcore 1.350
PCH Core Auto
CPU PLL 1.900V
DRAM Voltage 1.620V
DRAM Term AUTO
Ch-A Data VRef Auto
Ch-B Data VRef Auto
