[SOLVED] i7 11700k help
vladakv
206
35
10,640
13
Hello everyone.
I'm using NH-D15 and HwInfo, Core Temps and CPUID shows that core 0 and core 3 has minimal temp 0c, and curent and max temps read normal. Is it something bad?
Edit: it happens randomly - at first few minutes shows normal min. temps and random cores are showing 0 degrees. My Mobo is Z590 Torpedo with latest BIOS. Maybe Mobo BIOS is a problem? Or cpu?
Any solutions?
with my 11700K in HWiNFO core 0-7 always show relatively close temperatures.
min 30-35, max 60-66, avg 33-40.
keep a track on Core usage for a while.
if these same cores that are reading 0° are also showing low usage rates or aren't working as they should i would look into CPU as the culprit.
if usage is normal all across the board and it continues to show odd temperature readings i would look into the temperature sensors not working correctly.
vladakv
206
35
10,640
13
Likely, It's a bug...
