i7 2600 stress test @ 75c max temp
ejulzmartin
9
i just want to ask if the temp of my i7 2600 cpu under stress test is fine.. i'm using deep cool ice edge mini fs. my stress test temp is at 75 c while my idle temp is 50 c.. is it fine? if not, can you give me some suggestions to lower down the temp.. btw, im living in a tropical country so the room temp here is kind of warm. thanks!
Try re seating you cooler, apply very little thermal paste, a small dot(rice grain) in the middle & place the cooler on top of it, let the cooler's weight spread it evenly.
In country with high room temps, your cpu will run hot too, don't worry your temps aren't that high.
