fkr :
i keep my place pretty cool but i live in phoenix az and it has hit 130F out here. we are 100++ everyday. ...
What is your typical ambient room temp when running the tests? What CPU clock are you running at?
I'm using a Phanteks PH-TC14PE with 3 fans, CPU @ 4.7, 64GB DDR3/2400. With ambient room temp
of 27C, I get load temps of around 80C.
I have an older H100 on an i7 870, it gives load temps of about 75 with the CPU at 4.3.
I suppose what you could do is carefully remove the cooling block, see if the paste has spread
evenly across the chip. I've read on a forum recently that sometimes it's possible to attach these
blocks so they're not quite even in their mounting, though this was supposed to be more of an
issue with the normal H100.
Are you finding one core is a lot hotter than the others? Or are they all fairly similar?
Ian.
